Prettier code formatter for monkey-c
[EDIT]
The plugin seems to be working well (ok, there's room for debate, but it does for monkeyc what prettier does for javascript).
 - if you're already using npm, you can 'npm install --save-dev @markw65/prettier-plugin-monkeyc', and install the VSCode Prettier plugin.
 - if you just want to use prettier for monkeyc code, and only want to use it inside of vscode, and dont want to mess around with npm, you can just install https://marketplace.visualstudio.com/items?itemName=markw65.prettier-extension-monkeyc and it should just work.
[/EDIT]
So far there doesn't seem to be a code formatter for monkey-c. I've been writing quite a lot of monkey-c code recently, and I've really missed the auto-formatting provided by prettier for javascript (and many other languages).
A few days ago I decided to look into how to extend prettier. javascript isn't too different from monkey-c (or at least, monkey-c maps fairly cleanly onto a subset of javascript/typescript), so it seemed like it should be doable. I found a parser generator which already had a javascript grammar which produced an ast in the format prettier expects. In fact, the ast was fully compatible with prettier's estree printer. So I started from there, and modified it to parse monkey-c instead. Then I was able to delegate most of the printing to the existing estree printer in prettier. So after a couple of days of fiddling around I have something that prettifies all of my code in an acceptable way, and the code still works...
I've attempted to test it more thoroughly by running it on all of the Garmin sdk samples. It took a while to get everything to run through without errors (I guess there are a lot of features I don't use in my own code), and then a bit longer to get it to produce compilable code(!). But finally everything compiles, and if I compile in release mode, the prettified binaries are identical to those produced by the original code - so I didn't change the meaning of the code.
I created a GitHub repo to show what it does to the Garmin samples. There's a branch, original, pointing to the code as it was in the sdk. Then I prettified everything (branch pretty). You can browse the code, or just look at the actual changes.
I need to do a bit more cleanup and testing on my code, but I hope to publish the it on GitHub and npm as a Prettier extension within a few days - then it will be usable in VSCode via the Prettier extension. Meanwhile, feedback on the changes it made to the Garmin sample code would be appreciated.
Top Replies
All Replies
