Activity Elevation
Good morning,
Does anyone know the source of the Elevation in the connect IQ activity summary? Or is this an internal Garmin mystery?
Is there a way to manually force this to use GPS or Baro ?
  • In general, if the device has a baro, it will use that.  On devices without a baro. it's GPS.  GPS isn't that great for this in general.
    In the web based Garmin Connect, you'll see this in a full screen activity:
    It's enabled by default for devices without a baro, and I've seen it make a big fiffernce in that non-baro devices get much closer to "real"
    Here's what you see with the ? above:
  • Thanks, I actually did some testing in an open field, and this is what I found. Both altitudes ( the Baro and the GPS height ) seem to move around by themselves randomly.  If I move the watch, the baro takes 3 seconds to start reacting and about 7 seconds to display accurately again. This means a rapid movement up and down, is not actually registered at all in the raw baro pressure. ( Under say 3 seconds .    The GPS, I could not even get the reading to change at all. It seemed stabler than the Baro, but moving the watch up 2 meters or down 2 meters made absolutely no difference to the height reading.
    For my use case, unfortunately that is pretty useless, at best could be a trigger. Interesting that the GPS was stable, but I  couldn't seem to get it to change.
