Fenix 7 Multi GNSS GPS height accuracy
Good afternoon,
I am wondering if any developers here have access to any of these watches, and have seen if the GPS logs are more accurate than the version last used on the Fenix 6.
Typically if my watch is in a flat area, while recording activities I can have up to 6 or 7 meter vertical movements recorded. the accuracy with the height seems to be very poor.
Example a 1 hour 40 exercise on the same track at sea level, started off at 7 meters, at around 20 minutes the average altitude was about 20 meters, then 30 meters from an hour 10 to an hour 30, then at 1 hr 46  down at 8 meters.... All for an activity that is 98% at sea level 1 to 1.5 meters,
There were only about 4 instances in that entire session where the altitude was even close.
