Minor... just FYI for those who track bugs... the "true" and "false" keywords are colored in those last two statements in the Eclipse editor at least. I tried to post this in the BUG forum but that doesn't allow image attachments.
You can use inset code in the first post, or add an image on a post after that,
x==true and x==1 are different in monkey c, as in one case you are comparing two booleans, and in the other, a bookean and a number,
true and false are keywords, while 1 isn't.
Thx Jim - just an MVP to illustrate the parser bug... ignore the == 1 :-)
With VS Code, this is what you see. I doubt Eclipse will change.
good. I'll switch over soon.
