Instinct 2 support
Hi,
I've been asked by one of my users to support Instinct 2 for my Connect, but I can't get it working. I've downloaded SDK version 4.0.10, set it to the active version and restarted Eclipse and I can see Instinct 2 in the list of watches in the manifest. I can select it, however, if I try to create a run configuration it only gives me the option of Target API version 3.2.x in the dropdown. I believe it should be using 4.0.x. I already support the Venu2 and that has 4.0.x in the corresponding dropdown.
When I try to start the app it instantly fails with out of memory, nothing appears and the simulator memory plugin is totally blank as if it's not working.
Is there some trick to getting it to recognise that it should use 4.0.x, or is there a file or different SDK version I should try. I've tried 4.1.0-beta in case that was any better, but that didn't make any difference. I restarted Eclipse every after each change.
Thanks
David
