Hi!
I did one app, in the simulator it works perfect for the Vivoactive4s and for the Forerunner245. Once installed in the device, in the Vivoactive all goes perfect but it is not the case for the fr245. The problem is that the fr245 is a friend device, so I cannot play with it, he just told me that is not working. So I started to play with mine, the vivoactive.
I created a txt log file in GARMIN/APP folder and checked the output after using the app in the Vivoative4s, this is the result (note that even there is an error, it didnt crashed in the device and the simulator):
Error: Unexpected Type Error
Details: 'Failed invoking <symbol>'
Time: 2022-02-17T06:51:02Z
Part-Number: 006-B3224-00
Firmware-Version: '6.50'
Language-Code: spa
ConnectIQ-Version: 4.0.9
Store-Id: 87addc02-b241-4200-9757-4cf9d08c6027
Store-Version: 3
Filename: C2BF0125
Appname: Paris Velib
Stack:
- pc: 0x100003cf
- pc: 0x10000229
I checked the xml file (with your help Jim, thanks!!) and I found that the problem is in between pc="268436403" and pc="268436437" meaning lines 122 and 124 of my file (line 123 is commented). These are the lines:
