Extract points from location on screen relative to center of screen which equals current location.
If the center of the screen was equal to your location, is it possible that tapping on the screen (or in the case of button watches perhaps using a set distance in projected location and the direction you are facing to select) on for example the top left part could result in extracting coords (say for a waypoint) and save them somewhere then set that waypoints location to the center of the screen thus allowing you to select multiple waypoints that then connect as a route?
Just wonderingnif that would be possible for non map devices.
Crude example:
 The birds eye map is just to give an idea of distance.
