Hi,
Did you observe lately problems with the updates from OpenWeatherMap?
Thanks
Hi,
Thanks
hi,
not on my side,
which API do you use from OWM?
Getting OWM data has been working fine with my apps.
I tested my watchfaces with
https://api.openweathermap.org/data/2.5/weather
also with
https://api.openweathermap.org/data/2.5/onecall
I am receiving first time data and then it will stop updating or not I am not receiving anything
I tested also with some watchface from store, the same.
it may depends on your mobile (IPhone) and how do you initiate the API request?
Understand that the weather stations that OWM gets data from are not always updating in real time. When you say it's not updating, does it update every hour? Generally the weather doesn't change that fast, and if you check every 5 minutes you might not see changes.
dt in the json data is a time stamp. That should change even if things like temperature aren't.
I have an Iphone, what is wrong with this? And I have problems with all watchfaces, even those which are not created by me. Also I didn't changed anything in the last few months to my watchfaces and all was fine until a few days ago.
I was told that on Iphone, when there is update (connect or IOS) all the autorization is cleared and Garmin Connect does not run in the background anymore.
If you have issue with all watchfaces, that means it could be this.
Until few days ago: it could be Garmin Connect update or IOS update?
Yes, I know. But is simulator the temperature is changing, so there is an update from OWM
How are you requesting updates? If it's a background service, is it running when you expect in the sim or are you forcing it to run using Simulation>background events ?
I am using Simulation>background events
