How do you use getprojectedLocation?
I have in onUpdate
var g = Position.getInfo().position;
underneath it also in onUpdate it says:
if g != null {
g = g.toDegrees();
find (g[0],g[1]);  (which is of course the lat and longitude of g)
g = null;
……(excluded bitmap stuff here that occurs...
this takes my lat long from gps and an array of pngs of a map (not an actual map as its a non map device) and adjusts it around according to my gps position.
I would like to use projected location to move it on a button press or single tap (depending whether its touch or not touch) to mimic panning, only question is how do I do that?, looking at the toybox docs it only says
getProjectedLocation(angle as Lang.Numeric, distance as Lang.Numeric) as Position.Location
Get a Location object that is offset from the current position by a given distance and angle.
Parameters:
  • angle — (Lang.Float) —
    The angle in radians from north.
  • distance — (Lang.Float) —
    The distance from the current position in meters (m).
Returns:
  • Position.Location —
    The projected location.
    since Api level 3.0
    do I just replace Position.getInfo().position with Position.getProjectedLocation(heading, 10000)?
    If so then that sounds easy enough but I just wanted to make sure.
