Export Wizard - slow, multiple builds of each model. Can this be changed ?
When I use the Export Wizard in Eclipse to build my app for all of the devices that I support, the info in the Connect IQ console window indicates that each model is being built at least twice. Some are built 3 times. The build for export takes hours so I'm looking for ways to cut that time down, so if there are duplicate builds happening, I'd love to stop them.
I get Icon size warnings on most builds whether I'm building to run on the simulator or building the whole package with the Export Wizard.
I'm not concerned about the Icon warnings, but the warnings happen only once for each individual build when I'm building to run with the Simulator, and as you can see below, they happen 2-3 times when building with the Export Wizard.
I was going to attach a .TXT file but can't see how to make that happen. If you can explain how to do that, please do.
If you can help me stop multiple builds, or understand that this is necessary, please let me know.
Thanks
Here's the text in the .TXT file
Individual build of VA-HR
BUILD: C:\Program Files\Java\jre1.8.0_271\bin\java -Dfile.encoding=UTF-8 -Dapple.awt.UIElement=true -jar C:\Users\Jeff\AppData\Roaming\Garmin\ConnectIQ\Sdks\connectiq-sdk-win-4.0.9-2022-01-24-2154651d3\bin\monkeybrains.jar -o "C:\Users\Jeff\Google Drive\Sailing\Sail2WinApp\Sail2Win\bin\Sail2Win.prg" -w -y C:\Users\Jeff\Garmin\developer_key -d vivoactive_hr_sim -c 2.4.0 -f "C:\Users\Jeff\Google Drive\Sailing\Sail2WinApp\Sail2Win\monkey.jungle"
BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'vivoactive_hr' (40x33). Image will be scaled to the target size.
BUILD: Complete
Individual buid of 245 Music
BUILD: C:\Program Files\Java\jre1.8.0_271\bin\java -Dfile.encoding=UTF-8 -Dapple.awt.UIElement=true -jar C:\Users\Jeff\AppData\Roaming\Garmin\ConnectIQ\Sdks\connectiq-sdk-win-4.0.9-2022-01-24-2154651d3\bin\monkeybrains.jar -o "C:\Users\Jeff\Google Drive\Sailing\Sail2WinApp\Sail2Win\bin\Sail2Win.prg" -w -y C:\Users\Jeff\Garmin\developer_key -d fr245m_sim -c 3.2.0 -f "C:\Users\Jeff\Google Drive\Sailing\Sail2WinApp\Sail2Win\monkey.jungle"
BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'fr245m' (40x40). Image will be scaled to the target size.
BUILD: Complete
Export Wizzard build of VA-HR and 245 Music
BUILD: C:\Program Files\Java\jre1.8.0_271\bin\java -Dfile.encoding=UTF-8 -Dapple.awt.UIElement=true -jar C:\Users\Jeff\AppData\Roaming\Garmin\ConnectIQ\Sdks\connectiq-sdk-win-4.0.9-2022-01-24-2154651d3\bin\monkeybrains.jar -o "C:\Users\Jeff\Google Drive\Sailing\Sail2WinApp\Sail2Win\bin\Sail2Win.iq" -e -w -y C:\Users\Jeff\Garmin\developer_key -r -f "C:\Users\Jeff\Google Drive\Sailing\Sail2WinApp\Sail2Win\monkey.jungle"
BUILD: Complete
Package Manager: Export successful.
  • A full build of all the models I support just completed.... it took 4 hrs on a multi-core 2 ghz system.
    The Fenix 6 Pro shows 5 build passes.
    The Forerunner 55 and Vivoactive HR and many others show 2 each.
    Does anyone know what's happening with the multiple builds ?
    Don't know if it's helpful but here's the entire log -
    BUILD: C:\Program Files\Java\jre1.8.0_301\bin\java -Dfile.encoding=UTF-8 -Dapple.awt.UIElement=true -jar C:\Users\Jeff\AppData\Roaming\Garmin\ConnectIQ\Sdks\connectiq-sdk-win-4.0.9-2022-01-24-2154651d3\bin\monkeybrains.jar -o "C:\Users\Jeff\Google Drive\Sailing\Sail2WinApp\Sail2Win\bin\Sail2Win.iq" -e -w -y C:\Users\Jeff\Garmin\developer_key -r -f "C:\Users\Jeff\Google Drive\Sailing\Sail2WinApp\Sail2Win\monkey.jungle"
    BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'fenix5s' (36x36). Image will be scaled to the target size.
    BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'marqgolfer' (40x40). Image will be scaled to the target size.
    BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'fr645m' (40x40). Image will be scaled to the target size.
    BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'marqdriver' (40x40). Image will be scaled to the target size.
    BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'venu2' (70x70). Image will be scaled to the target size.
    BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'd2deltapx' (40x40). Image will be scaled to the target size.
    BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'fr945lte' (40x40). Image will be scaled to the target size.
    BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'descentmk2s' (40x40). Image will be scaled to the target size.
    BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'epix2' (60x60). Image will be scaled to the target size.
    BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'marqathlete' (40x40). Image will be scaled to the target size.
    BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'enduro' (40x40). Image will be scaled to the target size.
    BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'descentmk1' (40x40). Image will be scaled to the target size.
    BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'd2air' (60x60). Image will be scaled to the target size.
    BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'fenix5' (40x40). Image will be scaled to the target size.
    BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'd2charlie' (40x40). Image will be scaled to the target size.
    BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'descentmk2' (40x40). Image will be scaled to the target size.
    BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'fenix7' (40x40). Image will be scaled to the target size.
    BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'fenix6' (40x40). Image will be scaled to the target size.
    BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'venu2s' (61x61). Image will be scaled to the target size.
    BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'fenix6s' (40x40). Image will be scaled to the target size.
    BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'fenix6spro' (40x40). Image will be scaled to the target size.
    BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'fenix5x' (40x40). Image will be scaled to the target size.
    BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'fr245' (40x40). Image will be scaled to the target size.
    BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'fenix5splus' (40x40). Image will be scaled to the target size.
    BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'marqexpedition' (40x40). Image will be scaled to the target size.
    BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'fr645' (40x40). Image will be scaled to the target size.
    BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'venu2plus' (70x70). Image will be scaled to the target size.
    BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'venud' (60x60). Image will be scaled to the target size.
    BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'marqcommander' (40x40). Image will be scaled to the target size.
    BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'fenix6xpro' (40x40). Image will be scaled to the target size.
    BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'fenix5plus' (40x40). Image will be scaled to the target size.
    BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'fenix7x' (40x40). Image will be scaled to the target size.
    BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'fenix7s' (40x40). Image will be scaled to the target size.
    BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'marqadventurer' (40x40). Image will be scaled to the target size.
    BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'd2delta' (40x40). Image will be scaled to the target size.
    BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'fenixchronos' (36x36). Image will be scaled to the target size.
    BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'd2deltas' (40x40). Image will be scaled to the target size.
    BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'fr55' (35x35). Image will be scaled to the target size.
    BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'fr935' (40x40). Image will be scaled to the target size.
    BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'fenix6pro' (40x40). Image will be scaled to the target size.
    BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'legacysagadarthvader' (35x35). Image will be scaled to the target size.
    BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'venusqm' (36x36). Image will be scaled to the target size.
    BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'marqaviator' (40x40). Image will be scaled to the target size.
    BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'marqcaptain' (40x40). Image will be scaled to the target size.
    BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'fenix5xplus' (40x40). Image will be scaled to the target size.
    BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'fr945' (40x40). Image will be scaled to the target size.
    BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'legacyherofirstavenger' (35x35). Image will be scaled to the target size.
    BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'fr745' (40x40). Image will be scaled to the target size.
    BUILD: Complete
  • The version of java you are using can have a huge inpack on the speed.  Copen a command prompt and type
    java -version
    This is what I'm using right now,
    java version "1.8.0_241"
    Java(TM) SE Runtime Environment (build 1.8.0_241-b07)
    Java HotSpot(TM) 64-Bit Server VM (build 25.241-b07, mixed mode)
    But I've also used the latest openjdk,
    openjdk version "17.0.2" 2022-01-18
    OpenJDK Runtime Environment (build 17.0.2+8-86)
    OpenJDK 64-Bit Server VM (build 17.0.2+8-86, mixed mode, sharing)
    I just timed building an iq file of a fairly complex app that's supported on most watches and it was about 2 minutes with the openjdk I indicated.
  • You'll see apps get built more than once for a device where there is a world-wide version of the device as well as one or more APAC versions.  In the sim, you only build the WW version.
  • You’re right, there is a problem. Did you try restarting your pc?
  • Thanks Jim.
    I'll try out your recommendation concerning the JDK today.
    My current version shows -
    java version "1.8.0_301"
    Java(TM) SE Runtime Environment (build 1.8.0_301-b09)
    Java HotSpot(TM) 64-Bit Server VM (build 25.301-b09, mixed mode)
    That looks to me like a slightly newer version of what you're currently using.
    Given that, and the build times I'm seeing, I wonder if there's something else wrong.
    After timing a single build for the VA-HR I tried switching to a new workspace to see if that changed the build time. It didn't. Both builds took almost 2 minutes (1:55).
    I'm looking at OpenJDK.
    Is there something more that I need to know about installing OpenJDK ? Do I need to remove or disable the Java version that is currently installed ? Is there some way that I select which one is in use at any moment ?
    So far I'm not seeing answers to those questions on the OpenJDK site.
    And... did you install the Microsoft build of OpenJDK or the build that's on the OpenJDK site, and do you think that matters ?
    Thanks
  • That looks to me like a slightly newer version of what you're currently using.
    that's the problem that it's newer, if you use the 241 version it'll be fast.
  • Yes, 241 was the last fast one.  That's why I stuck with it so long!  Slight smile
    The openJDK I mentioned looks to be as fast, if not a bit faster,
  • Ahhh.... got it.
    If I'm going to switch to openJDK should I remove other java installs first, and I've found more than one place to get openJDK (microsoft, openJDK site, others). Where did you get your installer ?
    Thanks
  • With the version I got there wasn't an installer.  It was a zip file that I just unzipped and then had to set a couple of environment variable.
    I'd uninstall what you have now before switching.
