Hello- I have been working on a watch face targeted to just the epix2 and have a couple of noob questions on the AMOLED programming:
1) Is there any reason to use the setClip() method within onUpdate()? It is unclear from other posts or docs on whether this does anything on this device w/o partial updates.
2) Similarly, is there a reason to worry about the amount of computations or ms per onUpdate() call wrt power consumption or otherwise?
3) For lower power/burn in testing, is there any way in the Simulator to see what % of pixels you are using? (to stay under the 10% limit)
4) On my actual watch, after the lower power/burn in switch-over, the screen will then also dim after several seconds. Is there an event to indicate when that happens? Or, is there a property that I can check that indicates the watch is in this dimmed mode?
Thanks in advance!
