I have a watch face that I modified for the Epix Gen 2. It looks at whether the watch is in low power mode or not and displays either a simple watchface if in low power or a more complex watchface if in high power. Basically, it just uses onentersleep and onexitsleep to determine which watchface to display. It works fine when I have things set to always on display mode but when I turn off always on display mode when the device goes to sleep after the 8 seconds it will display the simple watchface for a few seconds in high power mode before actually turning off. It does in fact turn it off but I would like for it not to display the simple watchface. I'd like for it to go straight from my normal watch face to off. What I believe it needs is a check to see whether the watch is set to alway on or not. I couldn't find a parameter in the API documentation that is T/F for AOD. Is that parameter available to me via the api? I basically used the code from How to enable an "always-on" mode for Venu/AMOLED - Discussion - Connect IQ - Garmin Forums to modify my watchface for AOD. Thanks
