I'm not sure I understand exactly what is going on here, I would appreciate some help, line 55 has been highlighted.
using Toybox.WatchUi;
using Toybox.Graphics;
using Toybox.System;
using Toybox.Position;
using Toybox.Application;
class MapWidgetPanDelegate extends WatchUi.BehaviorDelegate {
enum {
ON_NEXT_PAGE,
ON_PREV_PAGE,
ON_MENU,
ON_BACK,
ON_NEXT_MODE,
ON_PREV_MODE,
ON_SELECT
function initialize() {
BehaviorDelegate.initialize();
function onTap(clickEvent)
var g_deg0 = Application.Properties.getValue("longitude");
var g_deg1 = Application.Properties.getValue("latitude");
var coord = clickEvent.getCoordinates();
var x = coord[0];
var y = coord[1];
if(x > 0 && x < 60 && y > 40 && y < 200)
System.println("left");
var long = (g_deg0 + 1.0);
Application.Properties.setValue("longitude", long);
System.println("works");
WatchUi.requestUpdate();
else if(x > 180 && x < 240 && y > 40 && y < 200)
System.println("right");
var long = (g_deg0 - 1.0);
else if(x > 60 && x < 180 && y > 0 && y < 60)
System.println("up");
var lati = (g_deg1 + 1.0);
Application.Properties.setValue("latitude", lati);
else if(x > 60 && x < 180 && y > 180 && y < 240)
System.println("down");
/* 55 */ var lati = (g_deg1 - 1.0);
else
System.println("cl");
Position.enableLocationEvents(Position.LOCATION_DISABLE, method(:onPosition));
function onHold(clickEvent){
WatchUi.pushView(new MapWidgetView(),new MapWidgetDelegate(), WatchUi.SLIDE_UP);
function onPosition(info) {
positionView.setPosition(info);
This is the properties file
<resources>
<properties>
<property id="latitude" type="float">50.987765</property>
<property id="longitude" type="float">0.987765</property>
</properties>
<settings>
<setting propertyKey="@Properties.latitude" title="@Strings.lat">
<settingConfig type="numeric" />
</setting>
<setting propertyKey="@Properties.longitude" title="@Strings.lon">
</setting>
</settings>
</resources>
