Both the va4 and venu1 now have beta firmware with CIQ 3.3.x!
In my initial tests with a va4, some of the new APIs are working, like respiration rate and sunrise/set, but I'm not seeing data for body battery or stress.
woooooooooow great!
I haven't seen yet that sunrise/set was available ! that is a shame there is not the Dawn/Dusk also.
look forward to testing it also! that probably means new SDK on its way!!!
Sunrise/set are in the Weather Module:
Hello,
I am using the CIQ online doc at
https://developer.garmin.com/connect-iq/api-docs/Toybox/Weather.html
And I do not these new entries -
What URL are you using ?
I'm using the doc that's included with the 4.1.0-beta 1 SDK. The web doc is for the current production SDK (4.0.8)
In Eclipse, under the Connect IQ menu use "API Documentation"
In VS Code, in the command palette, "MonkeyC: View Documentation", then "API Docs"
There you will see the doc for the SDK you are currently using.
