using Toybox.WatchUi as Ui; |
using Toybox.Graphics as Gfx; |
using Toybox.System as System; |
using Toybox.Application as App; |
class TextPickerView extends Ui.View {
// this is here for completeness but is likely calculated elsewhere in an app |
static const DEVICE_WIDTH = System.getDeviceSettings().screenHeight; |
static const DEVICE_HEIGHT = System.getDeviceSettings().screenWidth; |
static const INPUT_LETTERS = "ABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789"; // valid characters for input |
static const INPUT_CONTROLS = "<*"; // control characters for input |
static const INPUT_OK = "OK"; // what to render in place of the '*' (accept) character |
static const INPUT_BACK = "<<"; // what to render in place of the '<' (delete) character |
// these will likely need to be changed based on device |
static const PICKER_TITLE_POS = [95,30]; // title position |
static const PICKER_SUBTITLE_POS = [10,80]; // subtitle/info position |
static const PICKER_INPUT_POS = [10,DEVICE_HEIGHT/2]; // input display position |
static const PICKER_X = 174; // X coordinate of left side of picker |
static const PICKER_WIDTH = 32; // width of the picker (from left bar to right bar) |
// fonts to use for various text; will likely change based on device |
static const FONT_PICKER_TITLE = Gfx.FONT_SMALL; |
static const FONT_PICKER_SUBTITLE = Gfx.FONT_TINY; |
static const FONT_PICKER_VALUE = Gfx.FONT_MEDIUM; |
static const FONT_PICKER_LETTER_NOT_SELECTED = Gfx.FONT_XTINY; |
static const FONT_PICKER_LETTER_SELECTED = Gfx.FONT_TINY; |
var mTitle; |
var mSubTitle; |
var mMinChars; |
var mMaxChars; |
var inputStr = ""; |
var input_chars; |
var charIdx = 0; |
function initialize(title, subTitle, minChars, maxChars, prefix) {
mTitle = title; |
mSubTitle = subTitle; |
mMinChars = minChars; |
mMaxChars = maxChars; |
if (prefix != null) {
inputStr = prefix; |
input_chars = INPUT_LETTERS+INPUT_CONTROLS; |
View.initialize(); |
function onUpdate(dc) {
// clear whatever is on the screen to prepare for update |
dc.setColor(Gfx.COLOR_TRANSPARENT, Gfx.COLOR_BLACK); |
dc.clear(); |
var rightBarX = PICKER_X + PICKER_WIDTH; |
dc.setColor(Gfx.COLOR_WHITE, Gfx.COLOR_TRANSPARENT); |
dc.drawText(PICKER_TITLE_POS[0], PICKER_TITLE_POS[1], FONT_PICKER_TITLE, mTitle, Gfx.TEXT_JUSTIFY_CENTER|Gfx.TEXT_JUSTIFY_VCENTER); |
dc.drawText(PICKER_SUBTITLE_POS[0], PICKER_SUBTITLE_POS[1], FONT_PICKER_SUBTITLE, mSubTitle, Gfx.TEXT_JUSTIFY_LEFT|Gfx.TEXT_JUSTIFY_VCENTER); |
dc.setPenWidth(2); |
dc.drawLine(PICKER_X, 0, PICKER_X, DEVICE_HEIGHT); |
dc.drawLine(rightBarX, 0, rightBarX, DEVICE_HEIGHT); |
var pickerFontHeight = dc.getTextDimensions(input_chars.substring(0,1), FONT_PICKER_LETTER_SELECTED)[1]; |
var sidx; // index of character at the top of visible list |
var eidx; // index of character at the bottom of visible list |
var ch; // character under the cursor |
// draw the (visible) list of characters |
for (var i=(input_chars.length() > 5 ? -2 : input_chars.length()/2-1); i <= (input_chars.length() > 5 ? 2 : input_chars.length()/2); i++) {
if (i == 0) {
dc.fillRectangle(PICKER_X,DEVICE_HEIGHT/2-pickerFontHeight/2,PICKER_WIDTH,pickerFontHeight); |
dc.setColor(Gfx.COLOR_BLACK, Gfx.COLOR_TRANSPARENT); |
sidx = (charIdx+i) % input_chars.length(); |
if (sidx < 0) {
sidx = sidx + input_chars.length(); |
if (input_chars.substring(sidx,sidx+1).equals("<")) {
ch = INPUT_BACK; |
} else if (input_chars.substring(sidx,sidx+1).equals("*")) {
ch = INPUT_OK; |
// grey out the 'OK' if there aren't enough characters |
if (inputStr.length() < mMinChars) {
dc.setColor(Gfx.COLOR_LT_GRAY, Gfx.COLOR_TRANSPARENT); |
} else {
eidx = sidx + 1; |
ch = input_chars.substring(sidx,eidx); |
dc.drawText(PICKER_X+PICKER_WIDTH/2, (DEVICE_HEIGHT/2)+i*27, i == 0 ? FONT_PICKER_LETTER_SELECTED : FONT_PICKER_LETTER_NOT_SELECTED, ch, Gfx.TEXT_JUSTIFY_CENTER|Gfx.TEXT_JUSTIFY_VCENTER); |
// draw the string entered (so far) |
dc.drawText(PICKER_INPUT_POS[0], PICKER_INPUT_POS[1], FONT_PICKER_VALUE, inputStr, Gfx.TEXT_JUSTIFY_LEFT|Gfx.TEXT_JUSTIFY_VCENTER); |
// draw the red cursor |
var tmpTextDims = dc.getTextDimensions(inputStr, FONT_PICKER_VALUE); |
// handle the case where the input string is empty, in which case the height will be zero too... |
if (tmpTextDims[1] == 0) {
tmpTextDims[1] = dc.getTextDimensions("A", FONT_PICKER_VALUE)[1];
dc.setColor(Gfx.COLOR_RED, Gfx.COLOR_TRANSPARENT); |
dc.fillRectangle(PICKER_INPUT_POS[0]+tmpTextDims[0], DEVICE_HEIGHT/2-tmpTextDims[1]/2+1, 8, tmpTextDims[1]+1); |
// draw the red rectangle around the selected letter |
dc.setPenWidth(1); |
dc.drawRectangle(PICKER_X,DEVICE_HEIGHT/2-pickerFontHeight/2,PICKER_WIDTH,pickerFontHeight+2); |
dc.drawRectangle(PICKER_X-1,DEVICE_HEIGHT/2-pickerFontHeight/2-1,PICKER_WIDTH+2,pickerFontHeight+2); |
function setCharIdx(idx) {
charIdx = idx; |
if (charIdx < 0) {
charIdx = charIdx + input_chars.length(); |
function charSelected() {
// are we adding something from the list of valid letters? |
if (input_chars.length() >= INPUT_LETTERS.length() && charIdx < INPUT_LETTERS.length()) {
inputStr = inputStr + input_chars.substring(charIdx,charIdx+1); |
} else if (input_chars.substring(charIdx,charIdx+1).equals("<")) {
inputStr = inputStr.substring(0,inputStr.length()-1); |
// if we aren't at the maximum number of characters, then set the input characters to all |
// and set the highlighted character to the back/delete char |
if (inputStr.length() >= mMinChars) {
charIdx = INPUT_LETTERS.length(); // the character after the letters is the back/delete char |
// if we're now at the maximum number of characters, change the input characters to |
// only the control characters and highlight the "OK" |
if (inputStr.length() >= mMaxChars) {
input_chars = INPUT_CONTROLS; |
charIdx = 1; |
