I am a newbie running Windows 10, using VSC. I am trying to get through my first lesson Getting Started.
Connect IQ Basics (garmin.com)
https://developer.garmin.com/connect-iq/connect-iq-basics/your-first-app/
Everything seems to be running fine until I moved Development Directory and started all over.
No emulator spawns:
This returns in Terminal:
> Executing task in folder Thursdaytst2: C:\Program Files (x86)\Common Files\Oracle\Java\javapath\java.exe -Xms1g -Dfile.encoding=UTF-8 -Dapple.awt.UIElement=true -jar c:\Users\jwdcl\AppData\Roaming\Garmin\ConnectIQ\Sdks\connectiq-sdk-win-4.0.7-2021-11-29-437ff4cc4\bin\monkeybrains.jar -o bin\Thursdaytst2.prg -f c:\JDEVGarmin\Thursdaytst2\monkey.jungle -y -w -d fenix6xpro_sim <
ERROR:
java.io.FileNotFoundException:
at java.io.FileInputStream.open0(Native Method)
at java.io.FileInputStream.open(Unknown Source)
at java.io.FileInputStream.<init>(Unknown Source)
at com.garmin.connectiq.common.signing.KeyUtils.getPrivateKey(KeyUtils.java:105)
at com.garmin.connectiq.common.signing.KeyUtils.getPrivateKey(KeyUtils.java:91)
at com.garmin.connectiq.common.signing.KeyUtils.getPrivateKey(KeyUtils.java:55)
at com.garmin.monkeybrains.Monkeybrains.run(Monkeybrains.java:2611)
at com.garmin.monkeybrains.Monkeybrains.simpleMain(Monkeybrains.java:339)
at com.garmin.monkeybrains.Monkeybrains.main(Monkeybrains.java:368)
usage: monkeyc [-a <arg>] [-b <arg>] [-c <arg>] [-d <arg>] [-e]
[--Eno-invalid-symbol] [-f <arg>] [-g] [-h] [-i <arg>] [-l <arg>] [-m
<arg>] [-o <arg>] [-p <arg>] [-r] [-s <arg>] [-t] [-u <arg>] [-v] [-w]
[-x <arg>] [-y <arg>] [-z <arg>]
-a,--apidb <arg> API import file
-b,--apimir <arg> API MIR file
-c,--api-level <arg> API Level to target
-d,--device <arg> Target device
-e,--package-app Create an application package.
--Eno-invalid-symbolDo not error when a symbol is found to be invalid
-f,--jungles <arg> Jungle files
-g,--debug Print debug output
-h,--help Prints help information
-i,--import-dbg <arg> Import api.debug.xml
-l,--typecheck <arg> Type check [0=off, 1=gradual, 2=informative, 3=strict]
-m,--manifest <arg> Manifest file (deprecated)
-o,--output <arg> Output file to create
-p,--project-info <arg>projectInfo.xml file to use when compiling
-r,--release Strip debug information
-s,--sdk-version <arg> SDK version to target (deprecated, use -c
-t,--unit-test Enables compilation of unit tests
-u,--devices <arg> devices.xml file to use when compiling (deprecated)
-v,--version Prints the compiler version
-w,--warn Show compiler warnings
-x,--excludes <arg> Add annotations to the exclude list (deprecated)
-y,--private-key <arg> Private key to sign builds with
-z,--rez <arg> Resource files (deprecated)
The terminal process "C:\Program Files (x86)\Common Files\Oracle\Java\javapath\java.exe '-Xms1g', '-Dfile.encoding=UTF-8', '-Dapple.awt.UIElement=true', '-jar', 'c:\Users\jwdcl\AppData\Roaming\Garmin\ConnectIQ\Sdks\connectiq-sdk-win-4.0.7-2021-11-29-437ff4cc4\bin\monkeybrains.jar', '-o', 'bin\Thursdaytst2.prg', '-f', 'c:\JDEVGarmin\Thursdaytst2\monkey.jungle', '-y', '', '-w', '-d', 'fenix6xpro_sim'" terminated with exit code: 100.
Terminal will be reused by tasks, press any key to close it.
Any and all help will be greatly appreciated.
