Is it possible to completely remove some swings/properties for some devices?
I've got global settings for all devices but  for fr735 I'd like to REMOVE  unused  some- remove entire key not only change it.
e.g
all settings1, property1
all settings2, property2
fr735
if course it's connected with memory saving
  • TL;DR create a default resource folder and explicitly set fr735xt.resourcePath in monkey.jungle to exclude that folder.
    e.g.
    I think this should work (I do something similar in my apps, but I don't use language qualifiers. I believe language qualifier paths are separate from *.resourcePath, based on reading the default jungle file):
    1) Create a custom default resource folder for all devices except 735XT such as resources-default. Assign this path to a variable in your jungle file:
    default_resources = resources-default
    2) (OPTIONAL) Decide where you want resources that are common to all devices to go. e.g. You can use the normal base resource path, and/or you couild define a folder of your own (although it would be a bit redundan)t:
    common_resources = resources;resource-common
    3) Add these folders to the base resource path:
    base.resourcePath = $(base.resourcePath);$(default_resources);$(common_resources)
    or
    base.resourcePath = resources;$(default_resources);$(common_resources)
    4) Explicitly specify resources for 735xt, and don't include the default resource path you set or the default 735xt resource path set by the sdk
    fr735xt.resourcePath = $(common_resources);resources-fr735xt
    Of course, by doing this, you lose out on other resource paths that are normally automatically part of fr735xt.resourcePath. You can look at default.jungle in the SDK bin folder to see what they are, and add them back manually, if you need them:
    fr735xt.resourcePath = $(common_resources);resources-fr735xt;resources-semiround-215x180;resources-semiround
  • thx, I'm not sure but tested it and was merging as usual, must repeat
