Is it possible to check for compatibility of on-device settings?
I am using on-device settings, and right now my criteria for identifying whether a device is compatible is the API listed on the Compatible Devices web page (3.2 and up). Is there a way to check for this compatibility in the code? I want to be able to print it to the console so I can verify with the simulator, just in case a 3.2+ device is not compatible for some reason.
Also, when will the vivoactive3 Music actually be compatible with on-device settings? It uses 3.2, so it works in the simulator, but when I test my actual device it does not have the option for on-device settings. I understand this is because of the firmware.
