Toggling up/down in watchface question
How would it be possible to somehow display on watchface something else when e.g. you are toggling away from watchface and then back?
I mean you would save a state or a global variable that would increment and displaying something based on the values, lets say:
var page = 0 (would vary to 1, 2, 3)
Should you use onShow, onHide, these seems to work on simulator, but I guess not when toggling, switching a view like pressing down in watchface?
or should I use these?
// onStart() is called on application start up
function onStart(state as Dictionary?) as Void {
// onStop() is called when your application is exiting
function onStop(state as Dictionary?) as Void {
I've seen couple of watchfaces doing this kind of stuff, but wondering which place would be the correct place to detect this things and increment a global variable?
