Resolving "Unable to resolve entry class" error
I've just installed the VScode extension and am trying to create a new data field.  I setup the basic project and managed to get it to compile and run but then when I started to configure the project for the devices and SDK versions I actually wanted I started to get the following error:
> Executing task in folder MyTestProject: c:\Program Files (x86)\Java\jre1.8.0_311\bin\java.exe -Xms1g -Dfile.encoding=UTF-8 -Dapple.awt.UIElement=true -jar c:\Users\xxxxx\AppData\Roaming\Garmin\ConnectIQ\Sdks\connectiq-sdk-win-4.0.6-2021-10-06-af9b9d6e2\bin\monkeybrains.jar -o c:\temp\MyTestProject\MyTestProject\build\MyTestProject.prg -f c:\temp\MyTestProject\MyTestProject\monkey.jungle -y C:\GarminDevelopment\developer-key\xxxxxx -w -d fenix6spro <
com.garmin.monkeybrains.asm.AssemblerException: Unable to resolve entry class. Check the manifest file.
at com.garmin.monkeybrains.asm.EntryPoint.resolve(EntryPoint.java:136)
at com.garmin.monkeybrains.asm.Assembler.resolve(Assembler.java:1585)
at com.garmin.monkeybrains.asm.Assembler.resolve(Assembler.java:1602)
at com.garmin.monkeybrains.asm.Assembler.resolve(Assembler.java:1371)
at com.garmin.monkeybrains.asm.Assembler.assemble(Assembler.java:838)
at com.garmin.monkeybrains.compiler.Compiler.assemble(Compiler.java:1887)
at com.garmin.monkeybrains.ProjectBuilder.assembleProject(ProjectBuilder.java:808)
at com.garmin.monkeybrains.Monkeybrains.runPRGCompiler(Monkeybrains.java:1770)
at com.garmin.monkeybrains.Monkeybrains.compileApplication(Monkeybrains.java:1281)
at com.garmin.monkeybrains.Monkeybrains.run(Monkeybrains.java:2714)
at com.garmin.monkeybrains.Monkeybrains.simpleMain(Monkeybrains.java:339)
at com.garmin.monkeybrains.Monkeybrains.main(Monkeybrains.java:368)
ERROR: fenix6spro: unknown:0: Unable to resolve entry class. Check the manifest file.
But I've no idea what the error is and what I need to check in my manifest file which does include fenix6spro in the iq:products section.  This is happening on a Windows 10 system running VSCode 1.61.2 and MonkeyC 1.0.0
