I'm having an issue with ANT+ dropping out on the Edge 520. The Edge has Firmware version 5.20 and I'm using the Moxy Data Field version 0.2.
To replicate the problem:
- Create a data page with a Moxy Data Field and a native Cadence Data field.
- Pair the Edge to a Cadence sensor that is streaming data continuously.
- Leave the Moxy Sensor Turned Off so the data field keeps displaying the sensor number that it's looking for.
- Go to the view where you can see the data fields live.
Problem:
Every 30 seconds, the Cadence sensor will read 0 and then --- for about 4 seconds, then return to reading cadence.
It appears that something is going on with the Generic ANT channel when it times out and resets for not getting connected that is interfering with the Native ANT connection.
This was tested on a Fenix 3 and the problem did NOT occur there.
