Hi All,
I'm in the process of building my first watch app, and I have added configurable settings, in a settings.xml resources file with the following contents:
<settings>
<setting propertyKey="@Properties.api_key" title="@Strings.setting_api_key_title">
<settingConfig type="alphaNumeric" required="true" />
</setting>
</settings>
Then I'm trying to access with
var key = App.getApp().getProperty("api_key");
This all appears to be correct, but of course key is set to null because the setting hasn't been configured.
How can I access the settings on the device simulator?
File -> Edit persistent storage -> Edit Application.properties data returns a warning that the app has no settings. If I install it on my device, there is no settings button in Connect IQ.
Am I missing something?
Thanks in advance
