Hi, I have an issue where I think I'm using symbols in a dictionary correctly, but I cannot access them after creation. I have the following code, with the important lines being 30 to 37:
import Toybox.Application;
import Toybox.Lang;
import Toybox.WatchUi;
class countdownfieldApp extends Application.AppBase {
hidden var _datafield;
function initialize() {
AppBase.initialize();
// onStart() is called on application start up
function onStart(state as Dictionary?) as Void {
// onStop() is called when your application is exiting
function onStop(state as Dictionary?) as Void {
// Return the initial view of your application here
function getInitialView() as Array<Views or InputDelegates>? {
var settings = getSettings();
System.println("main seconds: " + settings.seconds);
_datafield = new countdownfieldView(settings);
return [ _datafield ] as Array<Views or InputDelegates>;
function getSettings() {
var x = {
:seconds=>Application.Properties.getValue("countdownSeconds"),
:alertVibrate=>Application.Properties.getValue("alertVibrate")
System.println("obj: " + x);
System.println("get seconds: " + x.seconds);
System.println("get seconds: " + x.alertVibrate);
return x;
function onSettingsChanged() {
_datafield.updateSettings(settings);
function getApp() as countdownfieldApp {
return Application.getApp() as countdownfieldApp;
When I try to run this I get a compiler error:
BUILD: /Users/x/.p2/pool/plugins/org.eclipse.justj.openjdk.hotspot.jre.full.macosx.x86_64_16.0.2.v20210721-1149/jre/bin/java -Dfile.encoding=UTF-8 -Dapple.awt.UIElement=true -jar /Users/x/Library/Application Support/Garmin/ConnectIQ/Sdks/connectiq-sdk-mac-4.0.5-2021-08-10-29788b0dc/bin/monkeybrains.jar -o /Users/x/Documents/projects/garmin-countdown/bin/countdown-field.prg -w -y /Users/x/Documents/projects/garmin-countdown/developer_key -d fr245_sim -c 3.2.0 -f /Users/x/Documents/projects/garmin-countdown/monkey.jungle BUILD: ERROR: fr245: /Users/x/Documents/projects/garmin-countdown/source/countdownfieldApp.mc:37: Undefined symbol "alertVibrate" detected. BUILD: WARNING: The launcher icon (30x30) isn't compatible with the specified launcher icon size of the device 'fr245' (40x40). Image will be scaled to the target size. BUILD: Complete Aborting launch due to failed build.
If I comment out line 37, the alertVibrate then the compiler succeeds, but then fails at runtime:
obj: {symbol (8389344)=>58, symbol (29)=>true}
Error: Symbol Not Found Error
Details: Could not find symbol 'seconds'
Stack:
- getSettings() at /Users/x/Documents/projects/garmin-countdown/source/countdownfieldApp.mc:36 0x10000371
- getInitialView() at /Users/x/Documents/projects/garmin-countdown/source/countdownfieldApp.mc:22 0x10000291
As far as my understanding of the documentation, symbols are defined on their first use:
The Monkey C compiler will assign a new value when it encounters a new Symbol. This allows a developer to use Symbol objects as keys or constant values without explicitly declaring a constant or enum. While Symbol values are constant for a build, their values may change across builds. https://developer.garmin.com/connect-iq/api-docs/Toybox/Lang/Symbol.html
so I'm not sure why either of these errors are occurring. Anyone have an idea?
