Direct download of windows SDK or assistance with sdk manager
So I downloaded the sdk manager and it says it has downloaded the sdk  and downloaded the device type I want to try and make apps and faces for but I can't go any further....  The image attached is as far as I am able to go... Please explain what I am doing wrong  and if possible a Direct download would be help full for windows... And yes I HAVE JAVA INSTALLED!!!!
thank you
Crags
  • Having this issue...  What should I do?
  • Are you getting this error when you run your app (which launches the simulator)? I think I've seen this every now and then, and while it's pretty annoying, I think it can be ignored. Are you able to continue if you click No or Cancel? Does it happen consistently?
  • I can dismiss it but as to the sim  I have not even managed to launch it....... Could someone explain the setup so I can get it running?
  • The sim automatically launches when you successfully build and run your app.
    Are you getting that dialog when you run your app? I've found in the past that I've seen it every now and then (maybe only after installing a new SDK) and once I dismiss the dialog, I'm able to get things working normally. (I might have had to run the app again.)
    In Eclipse, you can start the simulator on demand with Menu > Connect IQ > Start SImulator
    You can also launch the sim manually.
    1) Open %APPDATA%\Garmin\ConnectIQ\SDKs and navigate to the folder which matches your current SDK. (In your case it will be something like connectiq-sdk-win-4.0.4-2021-07-01-9df386fcd)
    2) Open the bin folder and double-click connectiq.bat. (If you don't have Explorer configured to show file extensions, you'll see two files called connectiq. Double-click on the one with the "gears" icon.)
    More generally:
    1) Find the folder of your current SDK by opening the following file:
    Windows: %APPDATA%\Garmin\ConnectIQ\current-sdk.cfg
    MacOS:  ~/Library/Application Support/Garmin/ConnectIQ/current-sdk.cfg
    2) This will contain the path to your current SDK. e.g.
    C:\Users\<USERNAME>\AppData\Roaming\Garmin\ConnectIQ\Sdks\connectiq-sdk-win-4.0.4-2021-07-01-9df386fcd\
    3) Under this folder, there is a folder containing binaries and a script to run the simulator:
    Windows: bin\connectiq.bat
    Mac/Linux: bin/connectiq
    Or, as a one-liner in MacOS Terminal:
    $(echo "~/Library/Application Support/Garmin/ConnectIQ/current-sdk.cfg")/bin/connectiq
