Sorry to ask such basics...
I understand the asynchronous coding concept, but what is the most elegant way to code a waiting period in order to display a text only half a second or less ?
not sure why you'd only want to display a message for such a short time, as I doubt a user would be able to see it/read it, but I'll display messages for say 10 seconds with an associated tone or vibration to let the user know to look.
Let's say I have a function called showMessage:
functon showMessage(msg) {
..displaySeconds=10;
..displayMessage=msg;
..makeNoise()
In widgets and device apps, I usually have a time that runs every decod, to update the display and do other housekeeping, so onTimer looks something like this:
function onTimer() {
.. if(displayTimer!=0) { displayTimer--;}
..WatchUi,requestUpdate()
Then in onUpdate, this...
..if(displayTimer!=0) {//display the message}
For a DF, instead of using a timer, the same basic logic can be used in compute()
Is this related to the fast response altimeter you're doing for skydiving? If so, when I was experimenting with reading the rawAmbientPressure value I noticed that the value only changes once per second, no faster. You can read it as fast as you like, but the value stays the same for a second at a time.
I'm not sure I understand your question exactly, but I think you may be talking about the timer function, which you specify in milliseconds and it fires repeatedly at that interval.
timer1 = new Timer.Timer();
timer1.start(method(:callback1), 1000, true);
Thanks for your answer. No, this is not related to the fast descent. Jim_m_58 answered the question very well.
