Are the activity data provided with a time delay?
I try to write my own datafield. However, I am a bit confused about the accessable of data. I use the compute(info) function to calculate my values and write them in a custom field to the fit file with setData(data). In case I write e.g. info.elapsedDistance to the fit file, it is delayed by one time step/second. Is it somehow possible to write the data to the current time step or in my case the time step before?
  • I find that when I just display data from ActivityInfo (not even recording it to FIT), there's a delay of roughly 1 second, so I don't think there's much you can do about it.
    If you wanted to be in sync with native data, wouldn't you have to display/write data from 1 second in the *future*?
    e.g. If I get the data for 1:20 at 1:21, then it's already too late for me to write 1:20's data.
    Unless you mean that you want to delay writing of native data by one second, which isn't possible.
  • That's not so good if you have also a delay of 1 second to display something. That would mean that it is a default behavior having a delay. (I haven't checked the display delay but I think it is in the line with the compute() call in my case. At least I get simultanous outputs on simulator and System.println())
    I want to write my data in line with the native data. Following you example, I get the data for 1:20 at 1:21, so that I can only write the 1:20 data with an delay of 1 second at 1:21. Of course, I can change the fit files later on to have the data in line but I prefer to have it correct out of the device.
  • That would mean that it is a default behavior having a delay.
    Yes, that's what I was alluding to. You can test this easily by reading ActivityInfo.timerTime, formatting it as [hh]:mm:ss, displaying it in your data field, and testing your data field alongside the native Timer field. When I've done this (as part of a more complex app), I've seen a delay of approximately 1 second. (Sometimes the delay can be longer or shorter)
    Yes I understand that but it's not possible for you to write your own delayed data "in the past" so to speak.
    I think the only way to theoretically accomplish what you want would be to delay the writing of all other (native) data, which also isn't possible.
  • When you do a setData, that doesn't write to the fit.  Fit files are written at most every second, so your setData may be written a second later.
    That's just the way it works.
  • That's pity but thank you for confirming my impression and checking my code indirectly.
