measuring vertical movement with accelerometer
In paragliding, it is important to be informed as soon as a vertical speed increases. This indicates a thermal (warm air climbing), so the location to stay to climb.
The standard way of measuring vertical speed is of course the barometer, but some devices to be more reactive, use the accelerometer.
This sounds simple if the device would be attached to a fix object. I would then just need to measure the vertical g. But on the wrist, it is necessary to develop an algorithm with the different g axis.
So, how to detect vertical movement (reference earth gravity) with a multiple axis g-meter?
Any idea/recommendation on how to do that ?
thanks all.
