String Iteration, Is it possible
Hi again guys,
I have now got a long list of code, that I would like to iterate - modifying the end of an App.Property key ( which I assume is a "string"),
The code is like this
}else if(Application.getValue("wptn") > 6) {
$.mWaypoints.add(Application.getValue("w7"));
$.mWaypoints.add(Application.getValue("lat7"));
$.mWaypoints.add(Application.getValue("long7"));
}else if(Application.getValue("wptn") > 7) {
$.mWaypoints.add(Application.getValue("w8"));
$.mWaypoints.add(Application.getValue("lat8"));
$.mWaypoints.add(Application.getValue("long8"));
where "wptn" is a number, and is the number of iterations I need to run, starting at 1
I need to be able to add the iteration number to the end of the partial getValue
Do you think this is possible?
for( var i=1; i < (Application.getValue("wptn")+1); i +=1) {
$.mWaypoints.add(Application.getValue("w"+"i"));
  • What you're describing is string concatenation (joining two strings), not "string iteration".
    The code you're looking for is:
    "w" + i
    In this case, i is implicitly converted to a string, then appended to "w".
    This can easily be tested without actually using properties with code such as this:
            for (var i = 1; i <= 10; i++) {
                System.println("w" + i);
    This code will print:
    w1
    w2
    w3
    w4
    w5
    w6
    w7
    w8
    w9
    w10
    If you want to use Application.getValue() as in your example above, you may need some guard code or a helper function to ensure that the return value is indeed a number.
    For example, in the following code, if the "wptn" property doesn't exist for some reason, then the code will crash because you can't add null and 1.
    Furthermore, Application.getValue shouldn't be called on every iteration of the loop, as it could be expensive in terms of CPU and I/O. Since the value is not expected to change, you can call it once and store the result in a variable.
    For example:
    var wptn = Application.getValue("wptn");
    if (wptn != null) {
        for (var i = 1; i <= wptn; i++) {
            var w = Application.getValue("w" + i);
            if (w != null) {
                $.mWaypoints.add(w);
            } else {
                // handle non-existent waypoint (System.println?)
    } else {
        // handle non-existent waypoint count (System.println?)
  • Thanks for your response, I learned more today!
