Hi community,
I have Cycliq FLY12 CE and Flare RT lights, both ANT capable. My idea behind this was to see battery status at my Edge 1030 and control the headlight from Edge screen (taillight is permanently on). But, this I could not manage. Neither built in Garmin tool nor any available ConnectIQ app worked for me. At the beginning the problem appeared to be just in light modes that the apps just did not supported the right modes that were supported by the lights. So I decided to create own datafield tailored to my needs. Should not be a problem with 25 years of embedded programming experience... I managed to create the datafield, although this Monkey C is sometimes quite strange for "normal" C/C++ developer, but then, finally the whole thing failed. Why? Because there seems to be some incompatibility between these lights and Edge1030 regarding the "light network" functionality, in which (according to ANT+ LGT profile documentation) higher level of compliance between the devices is needed as in this mode one light acts as a master and shared channel is used to control other (slave) devices. As result, the "Light network" is repeatedly forming 10x during a ride, lights disconnecting and connecting again. Very frustrating and, above all, dangerous. If the headlight goes off during a downhill in darkness, it may have fatal consequences :-(((.
So I decided to try again, but now give up ANT+ and go directly to ANT generic channels and control the lights directly with "Light network" DISABLED. As this method avoids using shared channels and the lights will be controlled independently, I hope I should be able to manage it a eventually even overcome some behavior of the lights that does not conform with the ANT standard.
Now the question: does anyone know if the Connect IQ API (namely the part related to generic channels) allows to do such thing? Does anyone have experience with similar thing? I am asking because I spent much time with this and would like to avoid spending another hours or days and finally fail due to missing access to something important through the API ..
Thanks
Jan
