Yes - this old chestnut again.
I am in the process of troubleshooting an issue in my app where depending on the watch, when I call up Activity.Info.Track I get null on some watches and not on others.
To fix this I changed to Position.Info.Heading, thinking that this would give me the same value, but instead I discovered in the Simulator, when I specify a constant Navigation Track - the return from Position.Info.Heading is changing constantly when simulate data is on ( as if I am walking in a straight line but rotating my watch around as if it is compass )
Can someone confirm for me please that Position.Info.Heading - - is the Compass heading of the 12 oclock position on the watch when held flat, and has nothing at all to do with your GPS position or track / path over the ground whatsoever?
The only instance method from Garmin that I can find to tell me which direction I am travelling ( North / South / etcc) , is the Activity.Info.Track
Are there limitations with Activity.Info.Track that stop it working with older watches ? or is there an alternative to give your GPS COG / Ground Track ?
