This seems like something that should be easy to solve but I always get a null value when trying to getValue some storage data. I want to make 2 customizable fields in the app settings. These are the properties, settings, and string.xml files, with 2 fields:
<properties>
    <property id="Lat_u" type="float">38.8551</property>
    <property id="Lon_u" type="float">-94.8001</property>
</properties>
<settings> <setting propertyKey="@Properties.Lat_u" title="@Strings.Latitude"> <settingConfig type="numeric" required="true"/> </setting> <setting propertyKey="@Properties.Lon_u" title="@Strings.Longitude"> <settingConfig type="numeric" required="true"/> </setting> </settings>
<strings>
    <string id="AppName">Test</string>
    <string id="Latitude">Latitude</string>
    <string id="Longitude">Longitude</string>
</strings>Then I have a background event, registered in the getInitialView() of the app, that tries to load the data like so:
using Toybox.Application.Storage;
(:background)
class BgbgServiceDelegate extends Toybox.System.ServiceDelegate {
	var APIKEY = ...
	var home_lat = Storage.getValue("Lat_u");
	var home_lon = Storage.getValue("Lon_u");
function onTemporalEvent() {
    Sys.println(home_lat);
I use the simulator to launch a background event. Before doing so I go to the App Settings Editor in Eclipse, select my app, and send the (unchanged) settings (I don't know if that is actually necessary given that I have defined some default values). Both fields are null when I try to load/print them from the app initialize() as well. Testing for the 645M.
