How to implement battery-charge detection ?
Hello,
Seeing this 'Battery Widget with automatic charge detection' app -
I have looked at the API (developer.garmin.com/.../index.html) for the means to implement some of that functionality (namely looked for battery/charging related listeners/events),
And could not find anything and therefore I assume I have overlooked it somehow -
Does anyone have any idea where it is/how to detect charge begin/end events ?
  • you can tell by the state of
    System.getSystemStats().charging
    There's no listener or event.  You just have to keep looking.
    One thing to note is if you plug into a pc/mac, your app stops running, so you can't use this, but you can see if there was charging by checking if the battery level increased.
  • Hello again :) and thank you,
    Checking the System.getSystemStats().charging flag has been the method I have been using, and found it to be unreliable precisely for the reason you have mentioned (plug to PC/charger stops the app and all flags/state/etc in code are lost and I do not want to write them to file-system/props for performance reasons) -
    And this app somehow gave me the impression there was a better way to detect battery-charging-related events.
