Bug Report Garmin Drivesmart 65
There is a bug in the software/firmware of the above device, in which a route that has been done on Basecamp, then uploaded to the device fails to work under, as far as I can tell one specific case.
If a route is started, that is past the start point on the route created, the device always wants to take you back to the start of the route, unlike older devices which asked if you wanted to go to the start of the route as an option.
However what does display on this model, is a message saying do you want to ignore "name"  (which is the last point on the route). Saying yes deletes the whole route and it then recalculates a new route which has basically screwed up the scenic route you had planned.
I would presume this is either a pointer fault to an array, where the pointer has not been reinitialised to the start of the route, when it pops up the question do you want to delete "name" or the route array has been inverted.
I would imagine that the intention was to delete the start point and not the end point of the route.
