ConnectIQ showDeviceSelection() doesn't work in iOS SDK
I'm trying to connect to my custom CIQ app using mobile iOS SDK. I've followed an example provided by SDK, converted calls to Swift, registered a custom scheme, set permissions, and everything looks fine.
Now I need to get a list of devices and for this I use
ConnectIQ.sharedInstance()?.showDeviceSelection()
That opens GCM as expected, but I have problems with following this part of the instruction:
"Once the user has selected which of the paired devices to share with the companion app, GCM will launch the companion app (via its registered URL scheme)"
  1. There is no any device selection dialog at this point. It simply opens GCM's last state (whenever it was left before)
  2. Whatever I do (e.g. clicking on connected or disconnected device) application function with openUrl param is never called
  func application(_ app: UIApplication, open url: URL, options: [UIApplication.OpenURLOptionsKey : Any] = [:]) -> Bool {
        print("Received URL: \(url)")
       ... process URL
Note also that Garmin iOS documentation suggests to override this function
  func application (_ app: UIApplication, open url: URL,  source application: String?, _ annotation: Any) -> Bool {
        return false
But that is deprecated and the first one must be used in iOS 14.1
How can I make openURL working?
In Android there is getKnownDevices function that works very well. Why don't we have anything like that in iOS SDK?
