Hi,
I've only started using ConnectIQ for a few days so apologies if I've missed anything. I would like to update a bitmap after a background event has run. I based my background event on this code as well as some other examples I found online. This is my Background.mc file:
using Toybox.Background; using Toybox.System as Sys; using Toybox.Communications as Comm; (:background) class BgbgServiceDelegate extends Toybox.System.ServiceDelegate { var APIKEY = "my key"; var lat = 38.8551; var lon = -94.8001; function initialize() { Sys.ServiceDelegate.initialize(); inBackground = true; } function onTemporalEvent() { var UNITS = (Sys.getDeviceSettings().temperatureUnits==Sys.UNIT_STATUTE) ? "imperial" : "metric"; var url = "https://api.openweathermap.org/data/2.5/weather"; var param = { "lat" => lat.toFloat(), "lon" => lon.toFloat(), "appid" =>APIKEY, "units" => UNITS}; var options = { :methods => Comm.HTTP_REQUEST_METHOD_GET, :headers => {"Content-Type" => Communications.REQUEST_CONTENT_TYPE_URL_ENCODED}, :responseType => Comm.HTTP_RESPONSE_CONTENT_TYPE_JSON }; Comm.makeWebRequest( url, param, options, method(:receiveWeather)); } function receiveWeather(responseCode,data) { var ret = (responseCode == 200) ? data :responseCode; Background.exit(ret); } }
Then, in the onBackgroundData() function of the App.mc class, I get my variables like so (I'm aware I haven't yet checked if they are null from an error code):
... function onBackgroundData(data) { var weather = data.get("weather")[0].get("icon"); var temperature = data.get("main").get("temp"); var weatherCodeValue = weatherCodes.get(weather); App.getApp().setProperty("weatherCode", weatherCodeValue); App.getApp().setProperty("temperature", temperature); Ui.requestUpdate(); }
And I assume I can obtain these variables using the App.getApp().getProperty() function. Based on a post in the same thread I linked earlier, it seems the initialize() function runs each time a background event has run, so what I did was put this code there:
class TestView extends Ui.WatchFace { // based on the value of weatherCode var icons = { "Snow" => Rez.Drawables.hud_snow, "Sun" => Rez.Drawables.hud_sunny, "Few Clouds" => Rez.Drawables.hud_partlycloudy, ... }; ... } function initialize() { WatchFace.initialize(); temperature = App.getApp().getProperty("temperature"); weatherCode = App.getApp().getProperty("weatherCode"); if (!weatherCode.equals(null)) { weatherHUD = null; weatherHUD = Ui.loadResource(icons.get(weatherCode)); Ui.requestUpdate(); } ... function onUpdate(dc as Dc) as Void { ... if (!weatherCode.equals(null)) { dc.drawBitmap(x_pos, y_pos, weatherHUD); } ... if (!temperature.equals(null)) { dc.drawText(x, y, Gfx.FONT_XTINY, Lang.format("$1$" + StringUtil.utf8ArrayToString([0xC2,0xB0]), [temperature.format("%d")]), Gfx.TEXT_JUSTIFY_LEFT); } ...
However, I don't believe this is the correct approach, as my app sometimes crashes when I simulate a background event with the simulator. What is the proper (and efficient) approach to do this?
Thanks.
