Difficulty using WatchUi.animate()
I'm trying to animate a chunk of text to simulate scrolling where I have some text with different fonts and colors.
My approach to this was:
1. Create an array to put my Text objects in my view class
2. When loading the text, add my text objects to that array (https://prnt.sc/12qlv31)
var foodName = new WatchUi.Text({
    :text => foodFullName,
    :color => 0xFFFFFF,
    :font => Gfx.FONT_TINY,
    :justification => Gfx.TEXT_JUSTIFY_VCENTER+Gfx.TEXT_JUSTIFY_LEFT,
    :locX => 40,
    :locY => 75 + j*50
mealText.add(foodName);
var foodQuantity = new WatchUi.Text({
    :text => meals[screenStatus.get("meal")].get("food")[j].get("quantity") + "g",
    :color => 0x999999,
    :font => Gfx.FONT_XTINY,
    :locX => 40,
    :locY => 90 + j*50
mealText.add(foodQuantity);
3. When the screen is tapped, this function is called
function scrollAnimation(){
    for(var i = 0; i < mealText.size(); i++){
        WatchUi.animate(mealText[i], :locY, WatchUi.ANIM_TYPE_LINEAR, mealText[i].locX, mealText[i].locY + 200, 0.25, method(:fx) );
4. And finally I'm drawing those objects in the onUpdate()
    mealText[i].draw(dc);
What am I doing wrong? The elements are rendered but there is no animations.
  • This code (built from your snippets above) works just fine for me.
    import Toybox.Application;
    import Toybox.Lang;
    import Toybox.WatchUi;
    import Toybox.Graphics;
    import Toybox.Lang;
    class TestDelegate extends WatchUi.BehaviorDelegate {
        hidden var _view as TestView;
        function initialize(view) {
            BehaviorDelegate.initialize();
            _view = view;
        function onSelect() as Boolean {
            _view.scrollAnimation();
            return true;
    class TestView extends WatchUi.View {
        function initialize() {
            View.initialize();
        hidden var mealText as Array<Drawable> = [] as Array<Drawable>;
        // Load your resources here
        function onLayout(dc as Dc) as Void {
            mealText = [] as Array<Drawable>;
                :text => "Blah Blah Blah",
                :color => 0xFFFFFF,
                :font => Graphics.FONT_TINY,
                :justification => Graphics.TEXT_JUSTIFY_VCENTER | Graphics.TEXT_JUSTIFY_LEFT,
                :locX => 40,
                :locY => 10
                :text => "More More More",
                :color => 0x999999,
                :font => Graphics.FONT_XTINY,
                :locX => 40,
                :locY => 40
        function scrollAnimation() as Void {
                WatchUi.animate(mealText[i], :locY, WatchUi.ANIM_TYPE_LINEAR, mealText[i].locY, mealText[i].locY + 200, 3.0, method(:fx) );
        function fx() as Void {
            mealText[0].locY = 10;
            mealText[1].locY = 40;
        function onUpdate(dc as Dc) as Void {
            dc.setColor(Graphics.COLOR_WHITE, Graphics.COLOR_BLACK);
            dc.clear();
            for(var i = 0; i < mealText.size(); i++) {
    class TestApp extends Application.AppBase {
            AppBase.initialize();
        function getInitialView() as Array<Views or InputDelegates>? {
            var view = new TestView();
            return [ view, new TestDelegate(view) ] as Array<Views or InputDelegates>;
    What app type are we dealing with here?
    IMO, if you are trying to scroll a multiline block of text, I think it would be better to not use multiple WatchUi.Text objects. Doing so is a bunch of memory and you'd be better suited to using an array of strings or a single TextArea. I'd probably not use WatchUi.animate() either.
  • How would you scroll through text then? i am also trying to figure it out for a smooth experience.. is there any way to show text and scroll it like you scroll lists or menus? thanks in advance!
