Hi,
How we can calculate Power NP? I am reading different ways but I tried with no success..
I need help
Best regards,
Hi,
I need help
Best regards,
Here's some pseudocode. You have to fill in your own implementation of a fixed-size queue.
class FixedSizeQueue() {
function initialize(size) {
// create queue with size elements
// TODO...
function enqueue(x) {
// insert x at back of queue
// TODO...
// if queue size > size, remove front item from queue
// TODO...
// ^ This can implemented with a fixed length array and two
// indexes which point to the first and last items in the
// queue
function size() {
// return the size of queue
// TODO...
class RollingAverage() {
var fixedSizeQueue;
var size;
function initialize(s) {
size = s;
fixedSizeQueue = new FixedSizeQueue(size);
function addData(x) {
fixedSizeQueue.enqueue(x);
// fixedSizeQueue only holds up to size elements
// If more elements are added, the oldest elements drop off
function getAvg() {
if (fixedSizeQueue.size() < size) {
return null;
} else {
// return average of all elements in fixedSizeQueue
// TODO...
class NormalizedPower() {
var numSamples;
var rolling_power_data;
var average_rolling_power_4;
function initialize() {
rolling_power_data = new RollingAverage(30);
average_rolling_power_4 = 0;
numSamples = 0;
// compute() takes the current power as an argument
// and returns either null or the calculated normalized power
// Assumption: this function is called once per second
function compute(currentPower) {
rolling_power_data.addData(currentPower);
var rolling_power = rolling_power_data.getAvg();
if (rolling_power == null) {
return null;
numSamples++;
var rolling_power_4 = Math.pow(rolling_power, 4);
average_rolling_power_4 = (average_rolling_power_4 * (numSamples-1) + (rolling_power_4)) / numSamples;
return Math.pow(average_rolling_power_4, 0.25);
class NpView extends Ui.SimpleDataField {
var np;
// init program
function initialze() {
np = new NormalizedPower();
// Assume compute() is called once per-second by the CIQ framework
function compute(activityInfo) {
var currentPower = activityInfo.currentPower;
var currentNP = np.compute(currentPower);
if (currentNP == null) {
return "--";
return currentNP;
And here's the original thread where the code was posted, with context: forums.garmin.com/.../normalized-power-fomula-by-garmin
