Just noticed an odd undocumented behavior change in CIQ 4.0 compared to older versions.
When using the drawing primitive fillCircle() (or any other fill method) for devices with CIQ < 4.0 the current pen width is ignored.
With 4.0 this has changed. The filled circle now has a diameter of 2*radius + pen width.
This change does not apply to fillRectangle().
Other fill methods may be effected as well, since I did not check every single method.
Could be only in the simulator since I can't test on a real device.
Travis.ConnectIQ was this change introduced intentionally?
