Compiler error 8 and error null, anybody?
Hi,
I'm messing with generating fonts, images and so on but I can't test as I have clearly done something wrong and whenever I try to compile I see:
ERROR: 8
ERROR: null
WARNING: The launcher icon (30x30) is smaller than the specified launcher icon size of the device 'approachs62' (35x35). Padding will be added to the image to center it.
The terminal process "C:\ProgramData\Oracle\Java\javapath\java.exe '-Dfile.encoding=UTF-8', '-Dapple.awt.UIElement=true', '-jar', 'c:\Users\Gaius Coffey\AppData\Roaming\Garmin\ConnectIQ\Sdks\connectiq-sdk-win-3.2.5-2021-02-12-6d31f4357\bin\monkeybrains.jar', '-o', 'bin\BG_KPAY_WF_SimpleUseful_Analog.prg', '-f', 'e:\gdcsoft\SVN_GARMIN\BG_KPAY_WF_SimpleUseful_Analog\monkey.jungle', '-y', 'e:\gdcsoft\SVN_GARMIN\GDCSoft_Export\gdc_developer_key.der', '-w', '-d', 'approachs62_sim', '-w'" terminated with exit code: 100.
Definitely _something_ have done here which is incorrect, but not much to go on...
Anybody any clues, or will I need to pick it back slowly item by item?
Thanks,
G
