I was contacted by a user of my radar widget that when ever they access my radar widget their Edge 1030 on FW 11.10 (latest release) will report that it drops the GPS signal for about 2 seconds then regains the signal. Once GPS has been accessed by a CIQ widget the device will lose GSP fix every 3-4 km until the unit is powered off. The user noted that they started seeing problems once they upgraded the device to 11.00 but also sees the problem with 11.10. Which make me suspect a possible FW issue. Since I don't have an Edge 1030, I contacted another user who has helped me troubleshoot somethings in the past. Below are the steps they went through which demonstrated the device worked properly on FW 10.2 but breaks once the device was upgraded to 11.00. The text below is the observation from this user confirming the behavior.
