https://www8.garmin.com/support/download_details.jsp?id=9505
I've highlighted some changes that specifically affect Connect IQ. This build should also address the problem many people have had connecting to sensors (e.g. heart rate monitor), which I know several Connect IQ developers have expressed frustration about. fenix 3 6.82 Beta Change Log :
- Added support for Auto Lock. (Settings > System > Auto Lock)
- Added support for previewing back light intensity as it is modified.
- Improved the colors used for sensor bar status icons.
- Improved the accuracy of floors climbed data.
- Fixed a potential issue where the current CIQ watch face could change if one had multiple CIQ watch faces and was upgrading from before software version 6.50.
- Fixed a potential issue where certain widgets could disappear from the widget loop after a software update.
- Fixed a critical issue where the watch would reboot when trying to Track Back a really long activity.
- Fixed an issue where auto lap distance for rowing was not being displayed in meters.
- Fixed a potential issue where a user could configure their lap alert banners to choose 'Interval Time/Pace/Distance' data fields for non-Open Water Swim profiles.
- Fixed a potential issue where Foot Pod was being used as a distance source in indoor Bike activities.
- Fixed a potential issue where one couldn't toggle the GPS setting for Row activities after profile creation.
- Fixed a potential issue where the steps history graph was displaying certain days twice.
There's a full set of release notes on the download page, but there are some additional things they've recommended folks check after the update:
- Your Fenix 3 re-pairs with your smartphone
- Your Fenix 3 re-pairs with sensors
- Your CiQ watch face is still active
- Widgets and Apps are still in order and present
- Your CiQ data fields are still set properly
- Your CiQ Apps and widgets are still set properly
- You are able to Sync with Garmin Connect Mobile
- Alarms or alerts continue to chime as you would expect
- Vibrations and tones continue to alert you in the manner in which you have them setup
- VO2Max and My Stats data is still present
