Hi,
I'm having some trouble making my app run against the Vivoactive 4s due to a missing font file, but I cannot figure out why.
The missing file appears to be called FNT_VIVOACTIVE4S_ROBOTO_SMALL_BOLD.monkeyface but it is not in any of my Connect SDK folders. I have SDK 3.2.5, 3.2.4, 3.2.3 and 3.1.9 and it will run with neither 3.1 or 3.2 specified.
There appear to be no fonts in <sdk folder>/bin/fonts in any of the SDKs beyond 3.1.9. The closest I can find to this file is in the root folder of ConnectIQ under /fonts, but they are .fnt and .md5 files, not monkeyface files and there is no font of exactly that name.
I have tried changing to various active SDK versions, but none of them appear to fix the problem.
Am I missing a file? Should I reinstall everything, or might that be a fix someone could suggest. Screenshot attached in case that helps.
(btw- I had a separate but similar problem on the 735xt, but that might be because I can't seem to get hold of an old enough SDK. I can ask a separate question if that helps)
