Hello,
I am trying to find out the memory-limit (for a watchface/widget/etc) of several devices,
And while some posts refer to 'devices.xml' (possibly under sdk/bin),
I do not have such a file (OSX BigSur, SDK 3.2.5).
Could someone please advise ?
Hello,
Devices.xml went away in CIQ 3.2. There is now a devices directory, with folders for each device under that and you can find the values in simulator.json for that device.
I'm not sure of the path to it on a mac.
Again, thank you,
However (for the sake of future reads of this post) a minor correction - it seems to be the Devices/<device>/compiler.json, which stores these values.
P.s.
Just in case you know/have an idea -
Unless I am mistaken, or missing something, it seems something has changed (in the SDK I guess ?),
Since till not long ago (till last week maybe ?), VA4 sim would show available memory as ~28k,
Whereas now it shows ~508k (which, BTW, matches its compilar.json)
You were probably running a data field when you saw 28k. 508k is for a watch face.
df:
Wf:
