I've found strange behavior of IF condition in a background handler.
In the main part I store some 'command' to be read in the background event handler:
Application.Storage.setValue("command", "do123");
System.println("command 'do123' is set");
Background.registerForTemporalEvent(Time.now());
In the background event handler the following code:
function onTemporalEvent() {
var command = Application.Storage.getValue("command");
System.println("command is read: '" + command + "'");
if( command == "do123" ) {
System.println("I heard it right");
} else if( command == "321od" ) {
System.println("thgir ti draeh I");
} else {
System.println("the cat is dead");
Background.exit(true);
... gives the result:
Background: command is read: 'do123'
Background: the cat is dead
If transmitted command is changed to int number (123 instead of "do123"), then it works as it is supposed to do.
Do I do something wrong here?
