Automatic UI tests with SIM
Is there any way to make some automatic UI tests (without writing them inside the code)?
Idea 1
I'm thinking about something like following:
  • start the SIM and switch a list setting every x seconds
  • after this test, switch to the next supported device (or to the next device inside a test cases defined devices) and repeat this
Anyone does something like this automatically? Maybe via a script (I've not seen any script support for the SIM yet though).
Idea 2
Alternatively, define settings with a script (e.g. a settings.xml file), start the SIM with this setting file and automatically export a screenshot.
Why?
I want to test all my data fields on all supported models - exporting screenshots automatically would be a great help. I would not care about speed, I can let this test run and then check the screenshots to find UI problems whenever the test is finished.
I'm open to any alternative idea as well...
  • This worked for me (Windows batch file, just like yours). (I run it in the root of my project folder)
    set SDK=%APPDATA%\Garmin\ConnectIQ\Sdks\connectiq-sdk-win-3.2.5-2021-02-12-6d31f4357\bin
    call %SDK%\connectiq
    call %SDK%\monkeyc -d fr245m_sim -f monkey.jungle -o tmp.prg -y PATH_TO_MY_GARMIN_DEV_KEY
    call %SDK%\monkeydo tmp.prg fr245m
  • Thanks for trying but please make sure to also completely reset the sim state before trying this via File > Delete all apps. I thought it is working as well in the beginning, but after I wrote my UI test script I saw, that the settings did not change so I went back to this simple test and found out, it does not work correctly.
    Resetting the sim state and starting an app from eclipse works but not from the command line...
  • It still works after clicking "Delete all apps". Just for good measure, I tried deleting the whole sim folder and it still works.
    Not sure what's happening differently here. I did the simplest test possible....
    Just for good measure I tried "fenix6xpro" and it works too.
  • That was already suggested, but they specified that they wanted to create the settings *programmatically*.
    I suppose another solution could be to script the app settings editor... Not as elegant as creating your own tool to do it directly tho.
    The other problem is that the app settings editor can fail to push settings due to the way it pushes them while an app is running. If the resulting memory spike crashes the app, then default settings will be applied.
  • Have you tried this with the simplest possible app? e.g. Nothing esoteric like multiple jungles, or shared code using symlinks or eclipse links, etc.
  • That helps me, I will try a simply example as well. It does not work with my setup, but I do use a more "complex" monkey.jungle with relative paths.
    I tried the exact same code as you tried and I also put the batch file directly into my project folder just as you did and tried with a resetted sim and it still fails.
    My monkey.jungle does look like following though (excerpt), I will make some more tests now:
    # Allgemein
    project.manifest = manifest.xml
    # SOURCE
    srcBase=source;../shared-src-core;../shared-src-data/source
    # RESOURCE
    resBase=resources;../shared-res-strings/resources;../shared-res-core/resources
    # RESOURCE - LOCALISED STRINGS
    base.lang.ces=$(base.lang.ces);../shared-res-strings/resources-ces
    base.lang.dan=$(base.lang.dan);../shared-res-strings/resources-dan
    base.lang.deu=$(base.lang.deu);../shared-res-strings/resources-deu
    base.lang.dut=$(base.lang.dut);../shared-res-strings/resources-dut
    base.lang.fin=$(base.lang.fin);../shared-res-strings/resources-fin
    base.lang.fre=$(base.lang.fre);../shared-res-strings/resources-fre
    base.lang.hrv=$(base.lang.hrv);../shared-res-strings/resources-hrv
    base.lang.hun=$(base.lang.hun);../shared-res-strings/resources-hun
    base.lang.ita=$(base.lang.ita);../shared-res-strings/resources-ita
    base.lang.nob=$(base.lang.nob);../shared-res-strings/resources-nob
    base.lang.pol=$(base.lang.pol);../shared-res-strings/resources-pol
    base.lang.por=$(base.lang.por);../shared-res-strings/resources-por
    base.lang.rus=$(base.lang.rus);../shared-res-strings/resources-rus
    base.lang.slo=$(base.lang.slo);../shared-res-strings/resources-slo
    base.lang.slv=$(base.lang.slv);../shared-res-strings/resources-slv
    base.lang.spa=$(base.lang.spa);../shared-res-strings/resources-spa
    base.lang.swe=$(base.lang.swe);../shared-res-strings/resources-swe
    base.lang.zhs=$(base.lang.zhs);../shared-res-strings/resources-zhs
    base.lang.zht=$(base.lang.zht);../shared-res-strings/resources-zht
    # default setting für build (Fenix 6X)
    base.sourcePath=$(srcBase);../shared-src-devices/source-fenix6x
    base.resourcePath=$(resBase)
    # GROUP 280 - Fenix 6X / Enduro
    fenix6xpro.sourcePath = $(srcBase);../shared-src-devices/source-fenix6x
    fenix6xpro.resourcePath=$(resBase)
    I may need to switch to start the sim from within eclipse to make sure that everything works - that's possible as well quite simply... That way my test script works but it looks so "dirty"...
  • Well I *think* the connectiq and monkeydo commands are fairly straightforward, so the only thing that eclipse can be doing differently is the equivalent of the monkeyc command (which can be different then what we have in our scripts if you have multiple jungles, for example).
    In Eclipse if you watch the console closely during a build (Run As > Connect IQ app), you will see a build command flash quickly by, soon to replaced by the run console itself.
    Click on the console selection icon to the far right of the console tab (looks like a console with a down arrow beside it -- hovertext is "Display Selected Console") and select the "Connect IQ" console.
    You will see a build command line such as:
    BUILD: C:\Program Files\AdoptOpenJDK\jdk-11.0.9.101-hotspot\bin\java -Dfile.encoding=UTF-8 -Dapple.awt.UIElement=true -jar C:\Users\USERNAME\AppData\Roaming\Garmin\ConnectIQ\Sdks\connectiq-sdk-win-3.2.5-2021-02-12-6d31f4357\bin\monkeybrains.jar -o PROJECTPATH\bin\PROJNAME.prg -w -y "DEVKEYPATH" -d fenix6xpro_sim -s 3.1.0 -f PROJECTPATH\monkey.jungle
    Everything after monkeybrains.jar is the arguments to monkeyc. Try comparing that to what you have in your script and see if it's different. If it's exactly the same (or equivalent), then something else is wrong here.
    Unfortunately the other commands (connectiq and monkeydo equivalents) aren't in the console log. (I haven't dug deeply enough to see if they're logged somewhere else.)
  • Thanks for the detailed response. I'm aware of all that and I even tried calling java -jar ...\monkeybrains.jar <ARGS> and  am using the exact same args in my script but I really do think that there is some special handling inside eclipse in the monkeydo part... Adding the -w + -s 3.2.0 to my script does not help even though they are the exact same commands as eclipse is logging in my case...
  • Cool, sorry for telling you stuff you already knew haha.
    In that case you can use a tool like Process Lasso:
    https://bitsum.com/
    Set it to log process launches and run your CIQ app from Eclipse.
    I see a cmd line that looks like this:
    java -classpath c:\Users\USERNAME\AppData\Roaming\Garmin\ConnectIQ\Sdks\connectiq-sdk-win-3.2.5-2021-02-12-6d31f4357\bin\monkeybrains.jar com.garmin.monkeybrains.monkeydodeux.MonkeyDoDeux -f PROJPATH\bin\PROJNAME.prg -d fenix6spro -s SDKPATH\connectiq-sdk-win-3.2.5-2021-02-12-6d31f4357\bin\shell.exe
    Of course, monkeydo.bat looks like this:
    java -classpath "%home%monkeybrains.jar" com.garmin.monkeybrains.monkeydodeux.MonkeyDoDeux -f %prg_path% -d %device_id% -s "%home%shell.exe" %test_flag% %test_names%
    So I don't really see where there's room for it to be anything other than what we expected, except for any possible tests (which you are not running.)
    Maybe try adjusting the current working directory that you launch your script from.
    I assume you're not doing anything unusual like launching Eclipse as an administrator or something.
  • This is the info that's logged when launching the sim from VS Code:
    Path: c:\Users\USERNAME\AppData\Roaming\Garmin\ConnectIQ\Sdks\connectiq-sdk-win-3.2.5-2021-02-12-6d31f4357\bin\simulator.exe
    Command line: simulator
    Plus connectiq.bat is very straightforward:
    @echo off
    start "Simulator" "%~dp0simulator.exe"
