Garmin Connect doesn't see that the app has settings for some reason if the app is sideloaded.
Thanks.
Thanks.
See https://forums.garmin.com/developer/connect-iq/w/wiki/4/new-developer-faq#app-settings
Another approach is to use on device settings for things like a watchface.
Here's an example of that:
https://apps.garmin.com/en-US/apps/c051f37a-8fad-4907-b124-0112fe010c91
Another thing you can try is creating a .set file for your app in the sim and copying that to the device with the proper name.(it can be case sensitive!)
perfect. thank you!
