suppose I build an aplication in this configuration:
what will happen let's say on fenix 5 which has ciq 3.1.8
should I have other sdk downloaded
You can build for all CIQ devices with the 3.2.4 SDK. Each device knows what CIQ it has and you'll see if there's an error with the sim if you try to so something that's not available on a certain target..
It means that it run:
- code call something what is accepted in 3.2.4 and if everything is ok it's build PRG
- PRG on device call something from it's CIQ and
-- throw exception if there is no it in devices CIQ and if I don't check it HAS
-- or return something from devices CIQ
true?
