I am working with "readKeyInt" to draw several bitmaps when the user uses the settings function.
The sim loads well with all the functions (time, background, etc). However, when I select the theme, the bitmap does not load upon command. Now, if I select a new theme on the simulator and then re-run the app, it loads the new image. The sim does not allow me to change the theme similar to how the background color is changed.
Has anyone experienced this challenge? Can someone point me in the right direction to enable the themes upon command?
