string resource files specified in jungle?
finally getting around to adding language support in my app and went down the normal route of adding in my translations in the resources-[lang] files.  quickly realized that eats up memory pretty quickly with all my strings i have and is going to cause memory issues in the older devices.
so, anyone know of a trick to load language resource files only for larger memory devices?
i'm already specifying specific source and resource paths based on the device, but not sure how i would incorporate languages into that same structure
ie,
edge1030.sourcePath= source;sourceEdge;
edge1030.resourcePath = $(base.resourcePath);resources\edge;
what i'm now after is
edge1030 AND lang="fre": resourcePath:$(base.resourcePath);resources\edge;resources\french;
Top Replies
All Replies
  • https://developer.garmin.com/connect-iq/reference-guides/jungle-reference/
    Localization Resources
    Localization strings are a kind of resource in Connect IQ, but have a slightly different syntax since multiple languages may be supported by a single device or device family. Suppose an application supports both English and Spanish, and all of the fēnix English localization resources are stored in a fenix-resources-eng directory, while the Spanish localization resources are kept in a fenix-resources-spa directory.
    # Set the fenix 5 English language resource location
    fenix5.lang.eng = $(fenix5.lang.eng);fenix-resources-eng
    # Set the fenix 5 Spanish language resource location
    fenix5.lang.spa = $(fenix5.lang.spa);fenix-resources-spa
    # Set the fenix 3 English language resource location
    fenix3.lang.eng = $(fenix3.lang.eng);fenix-resources-eng
    # Set the fenix 3 Spanish language resource location
    fenix3.lang.spa = $(fenix3.lang.spa);fenix-resources-spa
    The lang qualifier property is used in this build instruction to specify that a localization resource is being set, and is followed by an additional ISO 639–2 language code localization qualifier to indicate for which language the supplied resource locations are intended. A list of supported localization qualifiers can be found in the [Appendices][] chapter. Specifying an unsupported localization qualifier will result in an error at compile time.
    When specifying localization resources within Jungle files, the supported languages must also be set in a project’s manifest, otherwise the associated localization overrides will be ignored.
    You may also want to look at default.jungle in your installed SDK folder to see how the default language paths work.
    0 Former Member in reply to flowstate
    lovely.  thanks!
