System crash investigation. Vivoactive 4
Hello!
So a situation is.
I have an application that are already approved and downloaded several times. It uses BLE. Yesterday I got a report from a user with Vivoactive 4. The application causes a system crash while trying to use BLE. And it doesn't show  (IQ!) as I can see sometime, but it causes system restart.
Actually it looks like this
I tried to remove my functions one-by-one but I'm stuck on removing BleDelegate. So. If I remove the delegate or all internal logic, it stops crashing.
My Forerunner945, another Fenix5+, vivoactive3m are working without this problem. Sim works as well.
And another moment. We tried to create a file with the application  name under /garmin/apps/logs, but it's always empty. ERA is empty.
And the question is: How to investigate these situations? Are there crash dumps somewhere?
Thanks.
  • Yes, I've used more than 7 characteristics with no problem.  I forget the exact reason (it may have to do with hashing) and I think it's mentioned in the ble video from the 2019 summit, but how you define UUIDs can impact things.
    If you look at the thingy code you'll see
    TEMPERATURE_CHARACTERISTIC   = Ble.longToUuid(0xEF6802019B354933L, 0x9B1052FFA9740042L);
    PRESSURE_CHARACTERISTIC      = Ble.longToUuid(0xEF6802029B354933L, 0x9B1052FFA9740042L);
    HUMIDITY_CHARACTERISTIC      = Ble.longToUuid(0xEF6802039B354933L, 0x9B1052FFA9740042L);
    AIR_QUALITY_CHARACTERISTIC   = Ble.longToUuid(0xEF6802049B354933L, 0x9B1052FFA9740042L);
    notice the format - most is constant starting with 0xEF68
    but then there are 4 digits that are/can be unique
    then the rest is constant.  This is the most efficient format.
    While I didn't do this is the blog post I did for the raspberry pi, my current does use this method.
